یه چند مدت بود که دنبال این آرشیو می گشتم که بالاخره پیداش کردم :wow:
http://rs636.rapidshare.com/files/235599373/smps-switch-mode-power-supply.rar
شامل مدارات
شامل مدارات
AT-230
ATX-200 DTK
ATX-250
CODECOM-300-ATX
CODEGEN-350 ATX
LUNAR-200-AT
MORETEC-MP200 AT
PFC-400-ATX-
CODEGEN CG-07A
JNC 200-ATX
JNC Y-B200-ATX
ATX TO MAC
CODEGEN CG-07A
JNC_200-ATX
JNC_Y-B200-ATX
1.8Watt BUCK TOPOLOGY POWER SUPPLY
10Watt DUAL OUTPUT SUPPLY USING
145 W PC FORWARD CONVERTER
19Volt 3.6amp
20Watt DUAL OUTPUT POWER SUPPLY
24W SINGLE OUTPUT SUPPLY USING
3 PHASE POWER SUPPLY
3.6 W TRAVEL ADAPTER BASED ON
300W 24V.PDF
4.5V SMPS CD PLAYER FM RADIO
48 V 450 MA
5V-12-24V
5V-2.5A
6 V 10 W
6W DUAL OUTPUT SUPPLY USING
6W NON-ISOLATED FLY-BACK TOPOLOGY POWER SUPPLY WITH
6W SINGLE OUTPUT SUPPLY USING
80W ESBT QUASI-RESONANT WIDE RANGE SMPS
9.7 V 3.0 A
AUDIO SMPS
SG3524 13 VOLT 40 AMPER
TL494 450W
SINGLE OUTPUT REFERENCE BOARD 90 TO 264VAC
225 W (286 W Peak) Power Factor Corrected LLC Power Supply
30 W DC-DC Converter with DPA424
PKS606YN 36 W Continuous, 72 W Peak SMPS Power Supply
35 Watt SMPS Power Supply Using TOP 258PN
19.7 Volt, 3.3 Amp Notebook Adapter
24 Volt Flyback 50watt (70watt peak) smps
16Watt 16Volt Audio Amplifier SMPS Power Supply TOP245P
12 Volt SMPS Audio Amplifier Power Supply
ATX-200 DTK
ATX-250
CODECOM-300-ATX
CODEGEN-350 ATX
LUNAR-200-AT
MORETEC-MP200 AT
PFC-400-ATX-
CODEGEN CG-07A
JNC 200-ATX
JNC Y-B200-ATX
ATX TO MAC
CODEGEN CG-07A
JNC_200-ATX
JNC_Y-B200-ATX
19Volt 3.6amp
300W 24V.PDF
48 V 450 MA
5V-12-24V
5V-2.5A
6 V 10 W
9.7 V 3.0 A
AUDIO SMPS
TL494 450W
