پاسخ : شتاب سنج ADXL345 فروشگاه [فیلم+توضیحات+سوالات]
سلام به همگی
میشه کد پروژه اجرا شده را بهم بدید؟
بهش خیلی احتیاج دارم
مرسی از دوستان
سلام به همگی
مرسی از دوستان
$regfile = "m64def.dat" $crystal = 7372800 '$baud1 = 9600 Config Pinb.5 = Output Config Pinb.6 = Output Config Pinb.7 = Output Config Pind.6 = Input Config Pind.7 = Input Config Com2 = 115200 , Synchrone = 0 , Parity = None , Stopbits = 2 , Databits = 8 , Clockpol = 0 'Config Serialout = Buffered , Size = 30 'Clear Serialout Config Serialout = Normal Config Timer0 = Timer , Prescale = 64 Stop Timer0 Config Int6 = Falling Config Int7 = Falling Config Scl = Portd.0 Config Sda = Portd.1 Config Pind.5 = Input Adxl_cs Alias Portd.5 Led1 Alias Portb.5 Led2 Alias Portb.6 Led3 Alias Portb.7 'Sfior = Sfior And &B11111011 'Set Portd.6 'Set Portd.7 Enable Interrupts 'Enable Serial Enable Int6 On Int6 Int6_isr Enable Int7 On Int7 Int7_isr Enable Ovf0 On Ovf0 Ovf0_isr Reset Led1 Reset Led2 Reset Led3 Open "com2:" For Binary As #2 'Clear Serialout I2cinit Waitms 500 Set Led1 Set Led2 Set Led3 Const Adxl_add_write = &HA6 Const Adxl_add_read = &HA7 Dim A As Byte Dim B As Word Dim C As Byte Dim D As Byte Dim Tick_1s As Bit Dim Tick_5s As Bit Dim X_low As Byte Dim X_high As Byte Dim Y_low As Byte Dim Y_high As Byte Dim Z_low As Byte Dim Z_high As Byte Dim X As Word Dim Y As Word Dim Z As Word A = 0 Reset Tick_1s Reset Tick_5s Set Portb.5 Wait 1 Reset Portb.5 Wait 1 Set Portb.5 'Wait 1 Print #2 , "Initializing ADXL345..." 'Wait 1 Reset Portb.5 Print #2 , "ADXL345 goes in to I2C mode" Set Adxl_cs 'Wait 1 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H00 I2cstart I2cwbyte Adxl_add_read I2crbyte A , Nack I2cstop If A = 229 Then Print #2 , "ADXL345 responded" End If Waitms 500 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H2D I2cwbyte &H00 I2cstop Waitms 500 'initialize for Activity andinactivity interrupt I2cstart I2cwbyte Adxl_add_write I2cwbyte &H24 I2cwbyte &HA0 I2cwbyte &H45 I2cwbyte &H03 I2cwbyte &H77 I2cstop Waitms 500 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H2E I2cwbyte &H18 I2cwbyte &H08 I2cstop Waitms 500 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H31 I2cwbyte &H09 I2cstop Waitms 500 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H2D I2cwbyte &H08 I2cstop Wait 1 'Print #2 , A 'Wait 1 A = 0 Start Timer0 Do If Tick_1s = 1 Then Print #2 , A Incr A Toggle Portb.5 Reset Tick_1s End If If Pind.6 = 1 Then Reset Led2 Else Set Led2 End If If Pind.7 = 1 Then Reset Led3 Else Set Led3 End If Loop End 'end program Ovf0_isr: If B < 450 Then Incr B Else B = 0 Incr C Set Tick_1s End If If C = 5 Then C = 0 Set Tick_5s End If Return Int6_isr: Waitms 10 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H2E I2cstart I2cwbyte Adxl_add_read I2crbyte C , Nack 'I2crbyte D , Nack I2cstop Print #2 , "Int6: " ; C ; " " ; D Return Int7_isr: Waitms 10 I2cstart I2cwbyte Adxl_add_write I2cwbyte &H30 I2cstart I2cwbyte Adxl_add_read I2crbyte C , Nack I2cstop Print #2 , "Int7: " ; C Return
