سلام دوستان من به یک برنامه با بیسکام نیاز دارم (در صورت امکان با تاینی 13) که با PWM ال ای دی را به صورت سوسو کردن روشن خاموش کند
( همانند کرم شبتاب که نورش سوسو میکند )
$regfile = "M8DEF.DAT" $crystal = 8000000 Config Portb.3 = Output 'Config Timer2 = Pwm , Pwm = On|off , Compare Pwm = Clear Up|clear Down|disconnect , Prescale = 1|8|32|64|128|256|1024 Config Timer2 = Pwm , Pwm = On , Compare Pwm = Clear Up , Prescale = 8 Dim A As Byte Main: Waitms 200 Do Ocr2 = A Waitus 500 Incr A If A = 255 Then Waitms 1 Do Ocr2 = A Waitus 500 Decr A If A = 5 Then Gosub Ss Loop End If Loop End Ss: Waitms 20 Do Ocr2 = A Waitus 500 Incr A If A = 255 Then Gosub Aa Loop Return Aa: Waitms 1 Do Ocr2 = A Waitus 500 Decr A If A = 1 Then Gosub Main Loop Return
$regfile = "M8DEF.DAT" $crystal = 8000000 Config Portb.3 = Output 'Config Timer2 = Pwm , Pwm = On|off , Compare Pwm = Clear Up|clear Down|disconnect , Prescale = 1|8|32|64|128|256|1024 Config Timer2 = Pwm , Pwm = On , Compare Pwm = Clear Up , Prescale = 8 Dim A As Byte Main: Waitms 200 Do Ocr2 = A Waitus 500 Incr A If A = 255 Then Waitms 1 Do Ocr2 = A Waitus 500 Decr A If A = 5 Then Goto Ss Loop End If Loop End Ss: Waitms 20 Do Ocr2 = A Waitus 500 Incr A If A = 255 Then Goto Aa Loop Aa: Waitms 1 Do Ocr2 = A Waitus 500 Decr A If A = 1 Then Goto Main Loop
