با سلام خدمت اساتید عزیز
من دوتا ماژول HM-TRP دارم که دیتا رو فرستادم و گرفتم.ولی بعضی وقتا جای دیتاها عوض میشه.مثلا A002 رو میفرستم ولی بعضی وقتا 002A می گیرم.
برنامه هامم قرار میدم تا دوستان بهتر بتونن منو راهنمایی کنن. ممنون
فرستنده
فرستنده
$regfile = "m8def.dat" $crystal = 11059200 '$crystal = 8000000 $baud = 9600 $timeout = 4000000 '-------------------------Printer config---------------------------------------- Open "comb.1:19200,8,n,1" For Output As #2 '-------------------------HMTR config------------------------------------------- Open "com1:" For Binary As #1 'Config Serialin = Buffered , Size = 5 Dim W As String * 4 , I As Integer , J As Integer , Ii As Integer , Devicename As String * 4 Dim Beshmar As Byte Dim Device As String * 4 , Jj As String * 50 , Devicenumber As Byte , Lenvir As Integer , Dim A(79) As Integer , Aa(79) As Integer Dim A1 As String * 4 , Aa1 As String * 4 , Ischar As Byte Beshmar = 1 First: Do Device = Lookupstr(beshmar , Devicenames) Printbin #1 , Device Inputbin #1 , W 'Noecho Print #2 , W Wait 2 Beshmar = Beshmar + 1 If Beshmar = 5 Or Beshmar > 5 Then Beshmar = 1 Loop End Devicenames: Data "" , "A001" , "A002" , "A003" , "A004"
برنامه ی گیرنده [left]$regfile = "m32def.dat" $crystal = 11059200 $lib "glcdKS108.lbx" $baud = 9600 $timeout = 4000000 'Open "comd.0:9600,8,n,1" For Input As #1 'Open "comd.1:9600,8,n,1" For Output As #2 'Config Serialin = Buffered , Size = 5 Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 3 , Ce2 = 4 , Reset = 2 , Cd = 7 , Rd = 6 , Enable = 5 , Mode = 8 Open "com1:" For Binary As #1 Config Kbd = Portb Setfont Font8x8 Dim Numberofchoice As Integer , Numberoforder As Integer , Row As Byte , Devicename As String * 4 , Send As String * 200 Dim I As Byte , Kbd As Byte , B As Integer , Key As Byte , J As Byte , Jj As Byte , Ii As Byte , W As String * 4 , W1 As String * 200 Devicename = "A002" Do Cls Lcdat 4 , 1 , "Salam" Inputbin W ' Noecho Lcdat 5 , 1 , "W= " ; W Printbin W Wait 1 Loop End 'end program $include "font8x8.font"[/left]
